Duet. No Model Number
14 replies to this topic
#1 Squigger
Squigger
    Yamabushi
  • 84 posts
Posted 14 May 2010 - 12:56 PM
I have a whirlpool duet washer that keeps giving me an F28 error code. I can't find the model number anywhere. after I hit start the door will lock. it will let a little bit of water in, unlock, lock, and then it will do nothing for about 3 minutes and then the error code shows up. I have cleaned all connections. I'm completely stuck on this one. the tech sheet number is 8183018. any help would be greatly appriciated
#2 Squigger
Squigger
    Yamabushi
  • 84 posts
Posted 14 May 2010 - 12:59 PM
I also have put the motor and MCU in another machine and they worked fine. I believe my problem is the CCU but without a model number I'm not sure which one to order. I could be wrong too. I don't have much experience. expecialy  when it comes to duets
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 14 May 2010 - 02:42 PM
are all of the Panels on ? (and their respective switches)
front, bottom, etc ?
#4 bcippola
bcippola
    Kohai
  • Appliantologist
  • 269 posts
Posted 14 May 2010 - 04:57 PM
Tech sheet should have diagnostic test directions on ccu I think?
http://tinyurl.com/2uppgqk
page5-1
Edited by Samurai: Fixed Link
#5 Budget Appliance Repair
  • 4,930 posts
Posted 15 May 2010 - 01:07 AM
Read this discussion regarding the F28 error in the Whirlpool Duet Sport (He2/Kenmore).
http://applianceguru...rum2/24899.html
William Burk (Willie)
Eureka, CA 95501
#6 Squigger
Squigger
    Yamabushi
  • 84 posts
Posted 15 May 2010 - 03:41 AM
I have all 4 of the grounding switches taped down, the outlet I am using is grounded, and the diagnostics test doesn't work. when looking at the gounding system diagram on the tech sheet what are the R's?
#7 RegUS_PatOff
  • 33,588 posts
Posted 15 May 2010 - 03:54 AM
I don't think so ..
just cut & paste from the list at Job Aids
Whirlpool Duet Front Loading Washers
#8 Budget Appliance Repair
  • 4,930 posts
Posted 16 May 2010 - 01:24 AM
I don't think so ..
I don't believe this is the standard Whirlpool Duet washer, (it's one of the higher end Duet Sports but uses the standard Duet pump instead of the normal Duet Sport pump and shocks, looks like a conglomerate of the standard Duet and Duet Sport).
If you need to get an actual model# to look up parts - Page 2 and 3 have Whirlpool model#'s that use the tech sheet that is in this machine, (The first page, long model#'s are Kenmore models which would have a 110. in front of the indicated model#).
http://servicematter...pe=&CPIorderBy=
Eureka, CA 95501
#9 RegUS_PatOff
  • 33,588 posts
Posted 16 May 2010 - 03:47 AM
[user=36]Budget Appliance Repair[/user] wrote:
... it's one of the higher end Duet Sports but uses the standard Duet pump instead of the normal Duet Sport pump and shocks,
... looks like a conglomerate of the standard Duet and Duet Sport ...
If it's a WFW9200S   :headscratch:
from Service Update: Direct Drive Washer
DUET WASHER INFORMATION
New Manufacturing Division
Beginning January, 2007, some WFW9200S washers will be built in Monterrey, Mexico.
New washers will be distinguished by Engineering code and by serial number.
– Schorndorf Eng. Digits 00-09
– Monterrey Eng. Digits 10-19
– Schorndorf serial begins with CS
– Monterrey serial begins with HL
93% of the parts are interchangeable.
Unique parts include:
– Drive motor
– Drain pump
– Central Control Unit
– Tub
– Drum
– Cabinet
– Rear panel
It is very important to use the Engineering digit numbers in the model number
whenever ordering replacement parts.
#10 Squigger
Squigger
    Yamabushi
  • 84 posts
Posted 17 May 2010 - 08:50 AM
is it possible to find a part number on the old parts. theres about 3 different numbers on the CCU. I ordered a new one and put it in. it gave me an F99 error. I'm assuming its the wrong part
#11 RegUS_PatOff
  • 33,588 posts
Posted 17 May 2010 - 08:55 AM
what part number did you order ?
and what would those (3) part numbers on the "old" one  be ?
and on the "new" one ?
#12 certified tech group 51
  • 2,625 posts
Posted 17 May 2010 - 05:56 PM
Do you have the digital display or is there L.E.D. lights ............ If digital display, you could be in the model numbers WfW8500SO........( Duet Sport )  No fault codes over F-34 just sd.......................
#13 Squigger
Squigger
    Yamabushi
  • 84 posts
Posted 17 May 2010 - 06:33 PM
its digital. I forgot to  mention in my first post that this machine was in a basement with about six inches of water. I replaced the MCU and the drain pump. that got it to drain. I have clean the motor and all connections. I also cleaned and checked all gounding switches. dont ask me why the guy wants to try and salvage it
#14 Budget Appliance Repair
  • 4,930 posts
Posted 18 May 2010 - 02:13 AM
If the CCU is the same as in the standard Duet Sport, (which I believe it is), the numbers on the control or on the board inside the plastic casing is not a part# that you can look up the control by,  (it says right next to the numbers on the stickers on three of these controls I picked up, "not a service part#", I did searches on the numbers on the tags on the plastic case and on the boards inside the case to see if I could determine what models they were used on and none of the numbers came up anywhere).
You're going to have to come up with the correct model number to order the correct CCU board or find someone that has the CCU with the same numbers as yours which then you could use their model number.
Eureka, CA 95501
#15 Squigger
Squigger
    Yamabushi
  • 84 posts
Posted 19 May 2010 - 12:26 PM
el: 32141 is the number on the plastic casing of the CCU
