Ice Cream in Freezer is soft , plus the water leaking problem
2 replies to this topic
#1 ds@26
ds@26
  • 2 posts
Posted 08 September 2005 - 11:42 AM
Hi,
Same refrigerator with the leak has soft ice cream in freezer,
though it is set on "D" with the coldest setting at "E". Could this be related to the water leaking problem?
Thanks for your quick reply.
ds@26
#2 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 08 September 2005 - 11:45 AM
If the freezer is warming up would suspect you ice is melting so this seems likely, you need to remove the rear panel in the freezer and see what the frost pattern is on the evaperator. Ice Cream freezes at 10 degrees so your freezer is warmer than this.
    Shōgun
  • Master Samurai Tech
  • 30,922 posts
Posted 09 September 2005 - 02:56 AM
Couple links that'll hepya get started:
Refrigerator Diagnostics
Refrigerator Controls
