Kenmore Leaking Front Loader
4 replies to this topic
#1 huemruz
huemruz
  • 2 posts
Posted 09 September 2005 - 03:05 PM
  Hello.
 I have a pool of water under my washer after each use.  I have a 2001 Kenmore Front Loader
Model # 970-C41062-00  (triple checked with flashlight!).  I took the top, back and front panels off and watched it through one use.  It drips from the bottom of the tub in several places but only during a fast spin cycle.  Any ideas?
  • 24,224 posts
Posted 09 September 2005 - 03:55 PM
Best case: loose tub bolts. They can be tightened:
http://fixitnow.com/...ion-mystery.htm
Worst case: bad tub gasket. It's a beeotch.
#3 huemruz
huemruz
  • 2 posts
Posted 12 September 2005 - 03:25 PM
[user=1]Samurai Appliance Repair Man[/user]
Thank-you.  I Tightened all the bolts and learned some new Yoga moves at the same time! Some of those bolts are little tricky to get at huh?  Our washer is dry and my wife thinks I'm handy!
Until next time.
  • 24,224 posts
Posted 12 September 2005 - 03:59 PM
YEAH! I knowed you could do it! It helps if you have elastic joints, too.
Good job! :cheers:
#5 Guest_Scott_*
Guest_Scott_*
  • Lurking at the Threshold
Posted 13 October 2005 - 03:15 PM
If it is a bad tube gasket, do you have recomendations on replacing it or helpful advice, photos etc... Thanks
