JLaingor
Capacity Plus Admiral Dryer
11 posts in this topic
Wont Start.Checked Door. Please Help.
p.s
cant find model or serial numbers
Check power, with meter.
checked meter its fine
Model and serial number is on the inside if the door.
You probably have a blown thermal fuse inside the dryer due to a vent that is clogged with lint.
model:LNC7764A71
serial: 11760902CT
rev: 11
Where is the thermal fuse?
I tried looking for it
Does the Drum Light work ?
no ?
check Thermal Fuse # 5
and check your Venting System
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
http://www.repairclinic.com/referral.asp?R=154&N=3344
ventilation is ok.
i got the fuse 5 out.
how do i know if its good?
no need to remove to test ..
do you have a meter (and know how to use one) ?
i have a meter
i know how to use it
it's a Fuse ..
either good (closed)
or bad (open)
