bob_julian
Whirlpool Duet Dryer won't start
3 posts in this topic
There's nothing as humbling as trying to fix an appliance!! I have a 3 year old Whirlpool Duet Dryer Mod. # GEW9200LW0 the won't start. The display flashes and beeps when the start cylce button is pressed. When I run the diagnostics mode, all the LEDs light and the display says "3E" (note that's not E3.) When I open and close the door, there is no change to the display and no beep. The door switch is 0 ohms when closed and open when the door is open. The tech sheet test#2 Motor Circuit Test step 1 - the resistance across P1-3 to P1-4 is 2 ohms with the connector plugged in; although the resistance of the card pins with the connector removed is open circuit. I can't find a reference to the "3E" code anywhere. Any assistance would be greatly appreciated. Thank you. Bob
Ouch!  I knew it was going to hurt!  Thanks for the help.  I was in over my head.
-Bob
