Kenmore 80 series NO WATER!
6 replies to this topic
#1 georgiagal
georgiagal
  • 9 posts
Posted 11 September 2005 - 09:09 AM
I am writing about my kenmore 80 series washer, model # 110.29852991. A few days ago it would not stop filling with water, so I replaced the water level control switch. Now I tried to wash my first load of clothes and NO WATER. So thinking it was just stuck in between cycles because of my trying to fill it several times a few days ago to see if the water level switch was working (which it worked perfectly a few days ago~~~But I never tried to actually wash a load!), so I filled it by hand with water and when it got to the rinse cycle again NO WATER!!!!!
I am thinking water inlet valve? Any other thoughts anyone??
#2 georgiagal
georgiagal
  • 9 posts
Posted 11 September 2005 - 09:31 AM
By the way it does everything else~~it spins, agitates, it just thinks it has water when there is none!
#3 exsearsguy
exsearsguy
    Kohai
  • 314 posts
Posted 11 September 2005 - 09:45 AM
When it would'nt stop filling with water you didn't turn the water off and perhaps forget to turn it back on?
#4 georgiagal
georgiagal
  • 9 posts
Posted 11 September 2005 - 11:04 AM
I really wish that were it, but no the water is on.
    Shōgun
  • Master Samurai Tech
  • 30,189 posts
Posted 11 September 2005 - 12:05 PM
I'm thinking you mis-wired the pressure switch, easy to do.
#6 georgiagal
georgiagal
  • 9 posts
Posted 11 September 2005 - 12:56 PM
I am a little confused (which is not hard to do for me,) but there was only one way to wire the switch, so how could I have miswired it? Also I tested the small and medium size water level out by running water and getting it to agitate right after I put the switch on a few days ago, but only today did I try to run a load, and there is no water unlike a couple of days ago when there was water after I had put the switch on.
By the way this washer is the pits!!! I have replaced the lid switch, motor coupler, and the water level switch all in the last 2 yrs, and it is only 5 years old to begin with!
    Shōgun
  • 30,189 posts
Posted 11 September 2005 - 03:31 PM
Yours must have the plug on it that only lets you connect ikt one way.
Ok, make sure the air hose is one the pressure switch tightly. Also, when you changed the switch and put the air hose on the new switch, was there any water in the tub?
