Kenmore gas oven model 362.7361891
4 replies to this topic
#1 wsmaugham
wsmaugham
  • 1 posts
Posted 16 June 2010 - 08:26 PM
The lower burner (bake) ignitor on my oven does not come on and therefore the lower burner does not ignite.  I took the bottom of the oven apart and was able to unscrew the ignitor but could not figure out how to detach the wires that lead to the ignitor from the back panel of the oven.  Anybody know how to do this? :X
#2 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 17 June 2010 - 07:49 AM
You have to go behind the oven and remove a cover to disconnect the plug unless you want to cut and splice the wires (not recommended)
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 17 June 2010 - 11:01 AM
some of the replacement Ignitor kits require you to cut & splice
(with included Ceramic Wire Nuts)
but after making the connections, you would still need to push the Wire Nut connections thru the hole towards the back of the Oven
#4 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 17 June 2010 - 12:53 PM
And I would also recommend (if you have to cut and splice) that you tape or heatshrink the wire nuts as well.
    Shōgun
  • Master Samurai Tech
  • 30,625 posts
Posted 17 June 2010 - 03:34 PM
I only use ceramic wire nuts when I have to do wire splices near the oven.
Ceramic wire nuts==> Click
But it's always best to avoid splicing if at all possible.
