Sub zero 680/s
eugkim
  • Replies 5
  • eugkim
  • stelgor
SubZero Serial number ?
1) Prior to Serial #1810000
2) starting with serial #1810000
3) Approximate Starting Serial #2127000
4) Starting Serial #2600000
  • 5 months later...
Hello Sensei,
Could you please email a link to me for the technical service manual for a Sub-Zero 680/S with S/N M2100289?
(Or, send it to the internal messenger on your Appliantology system.)
Thanks
