Bosch dishwasher shu5315 intermittent heating
4 replies to this topic
#1 jmh226
jmh226
  • 2 posts
Posted 17 June 2010 - 08:59 AM
Hi all,
This is my first post! I recently acquired a used bosch shu5315 dishwasher. It wasn't working well, long run times, stuck at 1 minute remaining, etc. All of the classic control board problems, so I opened the machine up and sure enough the control board was burned at the heater relay. I repaired the solder joint and voila! it worked...for the first few runs. Now it seems to sometimes work and sometimes not. I've measured the current coming in and it is at ~11 amps like it should be most of the time, but I ran the super heavy duty cycle yesterday and the heater was only pulling ~1.25 amps. Then I ran the diagnostic cycle and the heater was back up to normal amperage. I ran the regular cycle after that and it was fine. So it seems that I still have an issue with either the heater assembly or the control board. Any advice as to what the problem could be? Can the heater element work intermittently, or is it the kind of thing that just stops completely when it fails? I tend to think that perhaps my control board is bad, but I'd hate to blow $150 on that and then still have to replace the heater for $127... I'd appreciate any advice you can give me!
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 17 June 2010 - 11:25 AM
[user=67866]jmh226[/user] wrote:
.. Can the heater element work intermittently,..
no
could be another bad connection somewhere,
OR the Relay contacts are bad
(could be replaced)
    Shōgun
  • Master Samurai Tech
  • 30,523 posts
Posted 17 June 2010 - 03:36 PM
May have a partially burned solder joint at the heater relay on the control board. Take the control panel apart and have a look. Kill power first.
#4 denrayr
denrayr
  • 1,146 posts
Posted 18 June 2010 - 06:22 AM
yep. ive found that when one of the relay solder joints burns, the others are cracked and need to be touched up.
#5 jmh226
jmh226
  • 2 posts
Posted 20 June 2010 - 06:46 AM
Thanks so much to everyone for your help with this.  It sounded like the consensus was that the issue was with the control board, so I took the control board out and sure enough, as "denrayr" suggested, all of the heater relay solder joints (other than the burned out one that I had previously repaired) were cracked.  I resoldered them and now she's working like a charm again!  Thanks again! :)
