kstodd
Maytag Dryer, Model LDE8304ACE, squeaking sound
1 post in this topic
Dryer is approx. 9 years old and now is beginning to squeak when in operation. The dryer doesn't squeak continuously, just sporadically. My problem appears to be similar to this one, http://applianceguru.com/forum2/2741.html , except that I am only hearing a squeak, not a grind.
Do you also recommend that I replace the rollers? If so, do I need the same roller for my model or a different one (here is the roller from the thread referenced above: http://www.repairclinic.com/referral.asp?R=154&N=400518 ).
The dryer has been used a few times since this started. Is it wise to use it, or should we unplug? It was used a few times as I was hoping (wishing?) that maybe this was something that some WD40 might handle, but after reading the post linked above, that may not be the case.
Thank you.
