Kitchenaide refer KBLC36FKB00
deezus
I need this service manual thanks....The Inside of this refer is frosting up right above freezer and to the left on the back wall in one area...saw a diagram at the parts store this thing has 3 heaters??
  • deezus
Thank You....frost pattern is good so I don't think its a leak...it keeps frosting up inside the fridge right above freezer on back wall, lower left as you look at it. The door hinge is out of whack as well, so i was thinking maybe the door wasn't closing all the way causing this frost. But it is in the back under the little shelf above freezer compartment.
[user=65024]deezus[/user] wrote:
... maybe the door wasn't closing all the way causing this frost....
yes,
Try the George Wa$h1ngton test.
Close the Door on George and take him for a ride around the Door Gaskets and check to be sure he stays snug.
