  • Announcements
AFBear
Maytag washer major short!!
7 posts in this topic
HELP!!  I have a 12 year old Maytag LAT9200 washer.  After completion of a wash, the washer went dead.  Checked and found the fuse blown.  Replaced and it blew immediately.  A quick jump over the fuse block resulted in a tripped circuit breaker as expected.  I've checked for frayed wires and loose connections all the way down to the motor and everything looks fine.  Also, no signs of overheating anywhere.  Plugged in with the fuse out  does not trip the CB.  Does anyone have any suggestions as the proper sequence to isolate this short?  The schematic taped inside is not the best I've seen.  Any help would be appreciated!!!!  Thanks!!
Presume you're talking about the fuse on the lid switch assembly - generally, this blows if either the main switch or lid switch is stuck so that both are in the same position at the same time. Check the switches for correct operation.
Mad Mac - Thanks for your response!!  That is the fuse I was talking about.  Checked continuity on the lid switch: open when lid is open and closed when lid is closed - seems OK.  I'm not sure what you are calling the main switch???
I can't edit my messages but I just checked what my schematic calls the "check switch".  It's a small (1 1/8" x 5/8" x 1/2") white switch located in front of the lid switch and has a red lead in from the lid switch.  It shows lid open (RD to W-GN closed circuit) whether it is or not.  The lid closed (RD to BK) is always open.  This is obviously without power.  Is this your main switch?  It looks like it's stuck open, unless it needs power - -could this be the culprit???
Update:  when looking at parts, saw the check switch had a red button sticking out.  Mine was stuck in.  Now it seems to check OK: R to BK with button out (lid closed) and R to W-GN with button in (lid open)
Sounds like you fixed it without really trying :cool: (I love those ones). Pop a fuse in and see how it goes. I'd put a new check switch on the "to do" list in any event.
I also stand corrected, I should have referred to "main switch" and 'check switch" earlier.
Thanks for your help Mad Mac!!  We're back in business.  The wife's happy so I'm happy!!  I'm still going to replace the check switch since it's <$10.
Thanks again!!  This is a great forum!
