manodad
Kitchenaid sequence
2 posts in this topic
My KitchenAid Diswasher has the "Normal" light on steady (no blinking).  I once had the same problem and the serviceman (who I really don't want to call again), pressed the buttons in a certain sequence and all worked well.  Do you know this sequence or another way to fix this problem?
Model # KUDM01TJ
These #'s appear on the manual under the model # but I don't know if they mean anything...
8269906A
Stuart
This should be the tech sheet, not sure without the rest of the model number that is on the unit itself......should tell you the info...
