Bosch Dishwasher SGV4313GB/13
26 replies to this topic
#21 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 31,395 posts
Posted 16 September 2005 - 10:30 AM
They're right there at the front lip. Look, I plucked out your wiring diagram from here...
#22 Samurai Appliance Repair Man
    Shōgun
  • 31,395 posts
Posted 16 September 2005 - 10:31 AM
And I flipped it over and there's your connection diagram...
OK. Get to work!
#23 dazza
dazza
  • 15 posts
Posted 17 September 2005 - 04:45 AM
One of the triacs on the control box PCB (the middle one)has a big hole in it!
Any idea of an equivalent part number to replace this with or will it have to be a new control box?
#24 Samurai Appliance Repair Man
    Shōgun
  • 31,395 posts
Posted 17 September 2005 - 04:50 AM
Good find, post a picture so we can all share in your delight.
If a triac is fried, there's undoubtedly other damage to the board as well. You're better off replacing it. Scroll up and use the "Easy Appliance Parts Lookup Form"
#25 dazza
dazza
  • 15 posts
Posted 23 September 2005 - 08:44 AM
new control box arrives. Fitted, power on...Nothing.
Opened up new control box, same triac has blown.:yikes::yikes:
£100 down the drain. Back to the drawing board. It's getting very near to the skip now.
Any control unit diagrams?
What's blowing this component?
#26 Kiwi-nadian
Kiwi-nadian
    Kohai
  • Appliantologist
  • 376 posts
Posted 23 September 2005 - 11:03 AM
Test the inlet solenoid/coil again, you are in the UK, so it should read between 1500 and 4500 ohms, if not, then this could cause a short in the circuit board.
please help us to help you, http://www.fixitnow.com/beerfund.htm
#27 dazza
dazza
  • 15 posts
Posted 23 September 2005 - 11:34 AM
4100 ohms.:(
