ShirleyPelicanfun
Kenmore Elite Dryer Error E1
17 posts in this topic
My Elite Dryer keeps stopping ...runs about 10 min. then stops.
Model number 110 61086000
 Ser. ML0403277
Type DDOT -ELE 2406028 EL 54
Can you tell me what part I need where I can order it and  how to replace it !
Thank you, Shirley
You need to replace the thermister located on the vent housing which is behind the bottom front panel.
This can be ordered thru this site using the Buy Appliance Parts link...
I tried that and it says mod. 110 61086000 isnt right. I checked it again, it is the number inside the dryer door on the plate... ser. ML0403277
I want to order the right part. can you help?
I took off the front panal below the door and theres a big black thing in the way so I cant see anything ...do I remove that??
:huh:  Please  Help!!!  I do NOT  see the part you are talking about!! Let me explain what I see. I took off the front cover off the dryer below the door. there is a big black thing covering the whole except for about 12" to the right side (me looking at it, my right side) of the dryer there are wires leading up to a white connector that plugs into a white connector that has two red plastic circles (looks like small lollipops) out of the connectors black and yellow wires. OK behind those wires is a black tube like thing that goes from front to back of dryer there are wires leading to that but I can barely see them holding a mirror inside but nothing there looks like the part your talking about. You said "ON  TOP  of the big black thing inside the front cover"  on my dryer there is no space between the big black thing and the door. What am I doing wrong??? This dryer cost me $1,000 'bout 5 years ago I don't want to trash it.
Shirley
:yikes:This Kenmore Elite Dryer is getting closer to the curb for junk every minute!
Model # 110 61086000    /    Ser: MLO 403277  /
Type DDOT-ELE2406028EL54
It is an ELETRIC dryer.... the link you gave me is for a gas dryer and mine does not have the silver thing in the picture only the two wires leading together with white conectors and red disks sticking out of them I see nothing that looks like the part you say I need ... I dont even see it in the link you sent me.  PLEASE   HELP
Leadimage.asp?productTypeID=0151200&brandID=0582&modelDesc=DRYER&modelNumber=11061086000&documentID=P0060276&documentTypeID=PLDM&documentClassCode=PM&titleType=BULKHEAD&titleID=00003&
:shock: Exactly where is the part in this pic. that I am supose to need?
As posted earlier in this thread reference # 42,,,,,
whirlpool-dryer-lint-filter-in-door2.jpg?dc=4675447341929098686
OK...here's what you should be seeing after removing the bottom panel. What I think is causing the confusion is that the thermistor is behind the lint chute. It may well help if you remove the chute. To do this, remove the lint screen from the dryer. then remove the two screws (just above the two red arrows). The chute will then pretty much fall off, revealing the thermistor.
:shock: Ok now were getting some place.... I got the black shroud off as you instructed...man is that got a lot of lint stuck in it... I do have a lot of air coming out the outside vent but I can see now theres a lot of build up...(could that be my problem)  can you send me another pic just like the last one with the shroud off and point to the part I need...theres a couple of them in there? Does it have wires pluged into it??
This is what you're looking for. It MAY be white in yours. It has two wires going to it - it's item 42 in the link Pegi posted above.
order part #3976615
