bassman70
Help! GE Dryer hums but won't start.
7 posts in this topic
Our GE dryer, model number dde7108pjlwh, has recently died. When we push the start button, the dryer emits a loud hum, but the motor will not turn. It sounds as if the motor is stuck, but I have no idea what is wrong... Any feedback would be greatly appreciated!
Either the motor is jammed with something in the blower housing or something else has the drum jammed.  If not your motor is ka-poot....
Can you turn the drum by hand without having to exert a herculean amount of force? If so, replace the motor: CLICK HERE.
Otherwise, there's a problem with the rolling components.
thanks, y'all. i'll take a look again and see what i find out.
   Put the timer in a run position. (anything but off).   Open the door.  Hold the door switch.  Give the drum a good counterclockwise whirl.  Report your findings.
well, it didn't seem to change the symptoms at all. drum turns freely, but still won't start.[user=2]Jedi Appliance Guy[/user] wrote:
Take the Samurai's advice and follow his link.
