Microwave trouble
11 replies to this topic
#1 Edtv
Edtv
  • 12 posts
Posted 22 April 2005 - 04:19 PM
Hello, Oh Wise Ones.
Once again I humbly seek your advice. This time its my microwave oven.
Kenmore
model #565.8844781
My wife went to use it this evening and as she was pressing buttons on the panel the thing went dark. No clock, no light inside and no panel beeps.
I checked the electrical panel and have found no blown breakers.
Otherwise I have gotten no further in troubleshooting than the initial stage of looking at it and saying "Huh!"
Any words of wisdom?
tia,
Ed
  • 24,708 posts
Posted 22 April 2005 - 06:27 PM
Start with the microwave diagnostic page.  Also, this table of microwave component tests will help.
#3 Edtv
Edtv
  • 12 posts
Posted 23 April 2005 - 06:52 AM
Thanks for the advice and for a great web site. The resources here have again helped me achieve victory!
I found the in-line fuse bad when I opened it up. Bought fuses, put one in and I'm back in business.
:banana:
I also bought a new fuse holder just in case but I'll wait and see if it blows again.
Thanks again.
Ed
  • 24,708 posts
Posted 23 April 2005 - 07:01 AM
Thanks for the follow-up report!  :rocker:
#5 Edtv
Edtv
  • 12 posts
Posted 18 May 2010 - 08:23 AM
Here I am again...same microwave as before.
Its blowing the fuse again.
This time it seems to blow consistently as soon as I start it.
I've replaced the fuse twice this morning and it blows within a second or two.
Once again I seek your wise counsel.
Should I try to fix it or just punt ??
Thanks again.
Ed
Kenmore
model #565.8844781
tia,
Ed
  • 24,708 posts
Posted 18 May 2010 - 09:29 AM
Lots of times, a blown HV rectumflyer will cause the fuse to blow. Check it out along with the capacitor and transformer. Be sure to discharge the capacitor when you get the control panel open.
#7 Edtv
Edtv
  • 12 posts
Posted 18 May 2010 - 04:25 PM
Have you a handy link to show me where the 'HV rectumflyer' may be and how to test it?
Thanks.
#8 RegUS_PatOff
  • 30,694 posts
Posted 18 May 2010 - 05:34 PM
click on Microwave diagram:
Sanyo Kenmore 565.8844781 Parts Lists & Diagrams
to test HV Diode, you would need a OHM Meter that uses a 9v Battery,
using the highest OHM scale, (2 Meg) youd should read "something" on "forward" and "infinite" when reversed
#9 Edtv
Edtv
  • 12 posts
Posted 19 May 2010 - 07:00 AM
Wow!! Ask and ye shall receive!
Thanks very much...you guys are awesome.
Well the HV cap reads as shorted. The needle on the meter goes all the way to the right and stays there.
I got no reading at all on the diode attached to to the capacitor.
What do y'all recommend??
Thanks again for all the help.
Ed
#10 RegUS_PatOff
  • 30,694 posts
Posted 19 May 2010 - 10:23 AM
A shorted Cap is common ..
The HV Diode is actually *many* Diodes in series and sometimes needs more voltage than an OHM meter uses...
You could try using a 9v Battery in series with the Diode and read with a Voltmeter
Some equivalent replacement Diodes are cheaper than others ..
  • 24,708 posts
Posted 19 May 2010 - 01:17 PM
I'd replace both. The rectumflyer isn't usually a lot of money anyway. The OEM rectumflyer for your m/w is NLA. But a generic will probably do-- they're all about the same.
Part link for rectumflyer==> Click
You'll want to match the capacitator as close as you can to the existing capacitance.
Part link for capacitator==> Click
#12 Edtv
Edtv
  • 12 posts
Posted 22 May 2010 - 12:07 PM
Picked up the hv capacitor locally, put it in there and...
all appears to be well. Its run for a couple of minutes with no problem.
Previously it wold run for about a second before it crapped out.
Thanks again for all the advice.
Ed
