mrickman
ge dishwasher draining problem gsd3404j01ww
3 posts in this topic
hello checked out piston assembly seems ok
wondering if fault with check valve assembly or dishwasher drain solenoid
system worked fine for a year now just wants to drain?
fills up & drains right away help....thanks
See if the drain solenoid is sticking open. If it is, you can tell by pulling down on the plunger and it'll close. Make sure it's not getting 120v on it when it shouldn't be.
Some dishwasher drainology help here:
http://fixitnow.com/2003/02/appliance-tip-of-day-dishwasher.htm
The advise I give this Grasshopper applies to you as well.  I believe your drain flap is warped out of shape or your drain solenoid is stuck closed.  You will have to check.  Use the Force.
