crabcruncher
Kitchenaid oven works, burners dont
4 posts in this topic
Oven works fine. All four burner elements do not heat. When burner switch is set to high nothing happens, even the indicating light for the burner doesnt come on.  Left the breaker off overnight , than turned it on next morning and tried burners. The indicating light came on for a millisecond than went off. Tried to turn burner on again, and ind. lgt. would not even flash at all. Shut breaker off for two hours and repeated test. Burner light came on for millisecond than went out. Tried again and burner light would not flash at all. This is same for all burners. Is there a relay that is fouling up? I have a fluke meter, and readings on wires that I disconnected from H1 and H2 show continuity on all four burners.
Tony
Since all top burners not working, I would suspect a burnt wire to control switches somewhere.
You checked continuity on all four elements from H1-H2 on all switches so you know the elements are ok.
Now you need to check L1-L2, (should probably be black and red wires), on each switch and see if you have 220Volts at the switches, if not then check each individually L1 to ground and L2 to ground, then which ever one doesn't show a reading of 110volts needs to be followed to find where power is being lost. Look for a wire that has slipped loose from a connector or burnt wiring at terminal block in back.
I don't have a wiring diagram for your unit so I don't know what the thermal disc under the cooktop controls, maybe shuts down all burners if an overheat condition occurs?
Thermal Disc ref#17 on this picture CLICK HERE
The other thermal disc/Bi-metal ref#20 is the fan control so that shouldn't have anything to do with it.
that unit has a cooktop relay that disables the top burners while cleaning- look for a failure somewhere in that circuit- try putting it in clean and then cancelling again
Willie, I did as you recommended and found no voltage on all L1 switch terminals. I than went to look for the burnt wire in the connection box, and there it was just like you posted. Well done. It all works again. Thanks alot.
Kdog, I saw that latch switch on the diagram on back of oven, it was the only component on L1 other than the wiring that could open the circuit. Thanks for your input also.
This is an excellent site with very prompt and top troubleshooters. And in the Immortal words of the Terminator....I'll be back.
Thanks again
Tony
