DaFaDa
Kenmore Dryer timer won't advance
1 post in this topic
Kenmore MOD No: 110 70602991
Ser: ML1004651
Type:  DWRJ-NAT-1206006FM22
I have seen similar issues here, but not the same.
When I start the dryer on Auto the element lights up and most of the time the heat begins to flow, but the timer does not advance.
If I run it on Timed cycle, it goes through the timed cycle and heats up, and if I run it a couple times, it will even dry; I just can't get the auto cycle to work.
I cleaned the dryer and the vent.
Thanks in advance for your suggestions
