LG Gas Range LRG80355
Started by dsherman, Aug 16 2010 06:04 AM
No replies to this topic
#1
Posted 16 August 2010 - 06:04 AM
Have had this range for some time now. Lately it seems that when we use the oven it not only shuts itself off, it then flashes the "locked" on the display. The door will at times be infact locked other times it is not. This happens while using different oven temps. (325 or 350) I have unplugged the range for 5-10 minutes then to plug back in and have it still display the flashing locked. I have also pressed and held the clear off button and there is no change. There are no error codes.
I have searched for this issue for a few days and have not found anything on a LG Gas Range. I also am having trouble making this happen as it works sometimes just fine.
TIA Douglas
TIA Douglas
