Evelone67
Kenmore Tumble Action Washer: Model 417.420-42100 wont drain, no hi speed spin
3 posts in this topic
My Kenmore front loader will not start the final high speed spin cycle. I assume it is because it also will not drain. I have checked the drain line and can hear the pump running, although the pump sound has changed. I will be replacing the pump tomorrow. Am I correct in assuming that the final spin cycle is inhibited by the fact that I still have water in the tub?
Yes, doesn't mean that there isn't some other problem as well, but a good place to start - if you open the unit up and check the pump manifold it may have some debris in it which is preventing it from draining - often just cleaning it out is all that's required
I'm sensing a haiku coming on. Wait for it... wait for it...
Front-Loading washer,
drain pump hummms but will not drain.
Gookus stuck in pump.
Read more: Frigidaire-Built Front Loading Washer Full of Water and Won’t Pump Out: A Haiku of Emptiness | Haiku | Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2009/04/23/frigidaire-built-front-loading-washer-full-of-water-and-wont-pump-out-a-haiku-of-emptiness/#ixzz0wnFL6JSu
Get appliance parts at http://parts.fixitnow.com
