Fridaire Gallery Front Load Washer won't drain / spin
51 replies to this topic
#21 AccApp
AccApp
  • 1,790 posts
Posted 19 July 2006 - 02:39 AM
If the motor runs without the belt, the door lock, timer and wiring harness can be eliminated as a source of trouble. Can you spin the drum by hand? Does the machine tumble under it's own power at any point in the cycle?
"When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth." Sir Arthur Conan Doyle.
http://www.fixitnow.com/beerfund.htm
#22 sammo
sammo
  • 2 posts
Posted 19 July 2006 - 03:53 AM
The drum spun by hand. I reattached the belt and repeated the test, and the motor spun and turned the drum. That was at the beginning of the wash cycle. It doesn't do anything during the spin cycle. Does that point to the speed control board?
#23 AccApp
AccApp
  • 1,790 posts
Posted 19 July 2006 - 04:10 AM
No, not really. You need to see if the timer is passing voltage to the board during the time when the drum should be spinning.
#24 Tebbetts
Tebbetts
  • 1 posts
Posted 31 July 2006 - 09:52 AM
Lock control unit part number 131888900.  I replaced this the unit and followed all of the directions.  Door lock works fine but now will not do final spin cycle.  Any suggestions?
#25 Ed F
Ed F
  • 1 posts
Posted 01 December 2006 - 09:38 PM
I'm glad I found this site, read about Frigidaire problems and was able to fix my washer myself, sent you a love offering for the beer fund, the photo helped also.
Thanks :cheers:
#26 TommasoPrimo
TommasoPrimo
    Ikkō-ikki
  • 25 posts
Posted 20 October 2007 - 05:02 AM
[user=1]Samurai Appliance Repair Man[/user] wrote:
Remove the front panel, take the suction hose off the pump and remove the coins and bobby pins from the pump impeller. Good to go.
Hello, I had this problem a couple weeks ago and found a bra underwire stuck in the motor.  After following your sage advice, everything has been working fine since then.
Yesterday, it stopped pumping the water out again.  I ran another load and it worked.  This morning, it wasn't pumping again, so I took it apart in search of yet another underwire.  This time there was nothing.  I did notice, however, that in trying to spin the blades by hand, there was a lot of "startup" resistance.  I put it all back together and its working fine again.
My question is whether the on again / off again nature of this problem, coupled with the difficult in hand spinning the blade is a good indication that the water pump in the nine year old machine needs to be replaced.  What do you think?  I certainly don't enjoy wrestling the red metal flangy things and getting stinky water all over my laundryroom floor.  Should I bite the bullet and replace the pump, or does it need some kind of WD40 lubrication treatment? I took the plastic cover off that sits just above the motor and the motor itself is pretty rusty looking.
Muchas Gracias and Feliz Cerveza!
#27 AccApp
AccApp
  • 1,790 posts
Posted 20 October 2007 - 07:38 AM
You can inadvertantly damage any motor by trying to run it in a locked rotor state. I'd replace the pump.
#28 BrntToast
BrntToast
    fellow,academy of sublime masters of appliantology
  • 1,306 posts
  • Flavorite Brew:i quit drinking the day i woke up nude on the hood of my car with my keys up my butt
Posted 22 October 2007 - 01:10 PM
Re. door lock kits....
DONT waste the time and effort changing the weight, throw it away
ive done frigidaire service for 5 +years and have changed hundreds of those kits and never changed the weight, i have yet to see one latch assembly damaged by the old weight
The only stupid question is the one not asked
hope i've been helpfull, if you wish to buy Brnt beer kick here
http://brnttoast.googlepages.com/home
feel free to prvt msg frigidaire questions my way
(i dont log in every day)
#29 TommasoPrimo
TommasoPrimo
    Ikkō-ikki
  • 25 posts
Posted 07 November 2007 - 01:03 PM
Okay, I bought the new pump (part number 131268401) but the connector locations for the green grounding wire and the "power harness" are on the left side of the pump instead of on the right like the old pump.
The photo shows the new pump on the right and the old pump on the left.  Notice that with the new pump, I'm having to route the two sets of wires across the top of the pump and, therefore, cannot fix the plastic, protective water shield (I guess this is what it is) across the top of the pump.  If I mount the pump with the power connectors facing right, then the discharge valve is on the wrong side.
What is the solution here?  Does Frigidaire sell some kind of wire extenders that extend the length of the ground wire and the wiring harness to solve just this problem?  If so, what are the part numbers?  Or, is there some way to reverse the direction of the discharge valve?
As always, grazie mille e birra molta!!
Tommaso Primo
#30 Dan Webster
Dan Webster
    Paw Paw
  • 1,385 posts
  • Flavorite Brew:Freebies
Posted 07 November 2007 - 01:59 PM
looks like a generic model. A common problem associated with tese washers is a generic sub pump. 1 size fitz all. and you have to figure out how to make it work. hok the wires up first then the hoses and try to make at least one screw hold the pump in place or leave it loose. It aint a space shuttle is it? wait with all these gadgets it might be!
"May the hinges of our friendship never grow rusty"
-old Irish saying
Buy me a beer through paypal: dannywebster@ymail.com
#31 TommasoPrimo
TommasoPrimo
    Ikkō-ikki
  • 25 posts
Posted 07 November 2007 - 02:10 PM
Thanks, I figured it out.  You have to disconnect the white plastic thingy that attaches to the hose and rotate the whole pump over.  As you said, its designed to be a bit universal and I just had to monkey around with it until I figured it out.
Cheers,
Tommaso Primo
#32 moonshouse
moonshouse
  • 5 posts
Posted 05 February 2008 - 01:00 AM
I HAVE A KENMORE 417-440925000 FRONT LOADING WASHER, IT WASHES FINE AND DRAINS BUT, ALAS, NO SPIN, I THINK IT IS TRYING TO ENTER THE SPIN CYCLE AND WILL GO ABOUT 2 SLOW ROTATAIONS EACH WAY THEN IT QUITS THE DISPLAY SIMULTANIOUSLY GOES BLANK AND THERE ARE 2 SETS OF BEEPS FOLLOWING, THE DISPLAY REMAINS BLANK AND THE MACHINE DOES NOTHING MORE. IN YOUR EARLIER POSTS IT SEEMS TO POINT TO THE SPIN CONTROL BOARD, BUT THERE IS NOT A LISTING FOR ONE ON MY MODEL
#33 AccApp
AccApp
  • 1,790 posts
Posted 05 February 2008 - 01:36 AM
Please feel free to start a new topic.
#34 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,403 posts
Posted 05 February 2008 - 01:59 AM
Outstanding suggesting, Sublime Master AccApp! ;)
#35 jcannon
jcannon
  • 6 posts
Posted 05 July 2008 - 10:43 PM
I thought I was pretty flippin' smart, finding this topic on this website with exactly the solution to my problem.
Unfortunately, there were still parts I could screw up, and I have.
I got the hose off, flooded my garage (could have used a little more warning to be prepared for that, by the way), and could not find an obstruction in either the hose or the pump. I hooked it back up, and viola, it drained, then spun it's heart out and I rescued the load of laundry and put it in the dryer.
I had one towel to "catch" the water (HA!), and it was a mess, so I tossed it in and thought I'd find out how my newly fixed washer worked. I was busy cleaning up the mess, blow-drying the indoor-outdor carpet, etc., when I noticed to my dismay that I hadn't seen the washer spin yet. Sure enough, I looked and it was in the final spin cycle, but it was just flopping around, and hadn't drained.
I'm smart enough that I left the cover off of the machine, but I'm not that fired up about going back in without a little more idea of what I'm looking for.
Should I have taken off the boot instead? Will I have the same water issue if I do that?
This is a fridgidare Gallery circa 1999, model # FWT449GFS2
Thanks for getting me this far and please get me the rest of the way!
#36 jcannon
jcannon
  • 6 posts
Posted 06 July 2008 - 08:07 AM
I have an update, and not a good one.
I took off the boot, found a few things but nothing substantial
I thought if I repeated the process of taking off the hose and draining the tub, I could rinse and spin another load of clothes. It didn't work, no draining going on at all.
I think I have a bad pump. Any ideas?
#37 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 06 July 2008 - 08:55 AM
FWT449GFS2 Wiring Diagram
Tumble Action Washers with AC Drive Motor (5995369211)   Posted Image
#38 jcannon
jcannon
  • 6 posts
Posted 06 July 2008 - 09:10 AM
Thank you. I have a neighbor who speaks that language.
#39 RegUS_PatOff
  • 33,588 posts
Posted 06 July 2008 - 10:50 AM
If he also speaks Heineken, you're all set...
#40 jcannon
jcannon
  • 6 posts
Posted 06 July 2008 - 11:15 AM
Luckily, he speaks "brownies," and my wife bakes mean ones.
