  • Announcements
amazon58
self cleaning nightmare
4 posts in this topic
Help, I have a GE electric range oven model #JBP24BY3WH , I used the self cleaning mode last week and ended it early as I had to leave my house and did not want to leave it on. Well since that point I can not get the oven to work,when I turn the dial to a temp the cleaning light blinks. I tried turnging the cleaning cycle on again it was on for 2 hours, the light never went off so once again I turned it to off. The light continues to blink ......help. I of course can not find my manual so any advice would earn double sessions to the fermenting gods!
Unplug the range, open the control panel, remove the wiring diagram/schematic page and post it here. If you can't scan in pages, fax it to me at 775-416-4449.
   How did you "turn off" the cleaning cycle the first and second time.  I was unable to pull up your model number.  You may simply need to put your oven into clean for 5 minutes and then cancel the clean cycle at the clock and wait for the door to unlock completely before turning any other knobs.
I turned it off by turning the temp dial clockwise to off . It has a digital clock and timer , I dont remeber if the timer was on , thansk for the tip I will try it .
