cannert
Need Wiring Diagram
11 posts in this topic
Hello,
I need a wiring diagram for my oven.  I had a few wire burn outs due to a suicidal mouse. The timed cooking switch is bad and the oven switch was damaged on terminal A.  I have a replacement oven switch, but I really don't want to replace the timer since I never use it.  I would like to by-pass the self cleaning and timed cooking functions.  Can someone email me the wiring diagram?
Thank you,
Tammy Canner
GE JBP24G0J1AD free standing range
That might be tough, should be there in the range somewhere unless some one removed it.  If you cannot locate it and no one here has one they can send to you call G.E with your model and serial and you can buy one from them......
Thank you for replying.  I figured it out.  I dropped orange timer connection to the second terminal from the bottom of the timer which by-passed all of the self cleaning and timed cooking.  I removed all of the self cleaning wiring for the selenoid, thermo. control, and thermostat. From the thermostat top left terminal, I daisy chained to the left post of the top element down to the left post of the bottom element.    I took the black and red from the thermo.cntrl straight to the oven switch and connect terminal J to the top element, right post which completed the circuit.  Everything seems to be working fine.  Testing the thermostat against the termo. cntrl switch and writing up a diagram  is all that remains.
Wow, good Job!!!!   All without a wiring diagram??   You are much braver than I would have been....bet the Samurai will want a pic of your work, he will want to feast his Valcan eyeballs on this!!
I used a wiring diagram that I downloaded for an old range with the time cooking feature only.  My range had the red leg of the 220 daisy chained , starting with the left front burner.  I  split the leg into three segments from the bottom junction terminal, in order to have functioning burners, etc if I have a future wire burn.  I took one segment straight up to the right burners, one straight up to the terminal A on the oven and timer, and one straight up to the left burners. Terminal M on the oven switch was connected to the bottom terminal of the second row on the thermo control.  Basically, I only needed to determine which terminals on my oven switch corresponded to the terminals on the older model's oven switch.
Good job, there......I am impressed.......;)
Damn good job! That earned you a promotion to Apprentice Appliantologist.
Cool!  Thanks.
 I also fabricated a safety switch from industrial hot glue for my trust y 1988 microwave when it broke the other day.  I used the hinge piece and molded the hot glue in a large glob at the end.  Then I filed it down to shape.  Works great.  My husband wanted to tape down the switch to the magnetron.  I said "no way".  All we need is for the kids to nuke themselves.
Might you be the long-prophesied Martha Stewart of appliance repair?
I think that I may be an apprentice Jedi knight. My father has detected the force in me. I have fixed my clothes washer twice and my dryer three times. Both units are close to being petrified due to their age. I may retire my washer as it's not cleaning as well, and we have a small farm with two tom girls... well three including myself. I have been reading the Saber posts and think it may fit the bill. My washer tends to eat lightweight clothing, requiring my seamstress alter ego intervention.
Tammy
Perhaps. One of our Master Appliantologists, Jedi Appliance Guy, would be the appropriate person to help you confirm this.
