GE SxS GSH25KGRBBB Serial: HG234687
micgla
  • Replies 5
  • micgla
  • appl.tech.29501
[user=3641]RegUS_PatOff[/user] wrote:
may be similar to 31-9072
Samutrai has it listed as  GE Arctica Pro SxS.pdf
