August
Goldstar microwave turntable not working
7 posts in this topic
My parents have the above microwave and the turntable has stopped working.  :X   Do you know why?
I would try to pull up the service manual if I could see a model number for this unit..
Goldstar Intellowave Even Heat System 1100W Sensor Touch....this will not get it.
I have the modle  & serial # now.
Model #:  MA2130W
Serial #:  309KM08249
Thanks for any help you can give me!!!:)
I will see if I can pull this up and read the manual for any repairs on this  ;)
36 page manual does not address the diagnosis of it not turning at all, only the removal of the motor for testing.  Guess you could access this and test it with your ohm meter, but we do not work on micorowaves and these are very dangerious if you do not know what you are doing. I would not suggest you trying this yourself, however this is their instructions for accessing this motor, with the unit un-plugged.
[align=left]K. REMOVING THE TURNTABLE MOTOR[/align]
[align=left]1) Remove the glass turntable.[/align]
[align=left]2) Remove the rotating ring ass’y by hand.[/align]
[align=left]3) Remove the turntable motor cover.[/align]
[align=left]The turntable base cover is easily removed by[/align]
[align=left]pinching the six parts with wire cutting pliers.[/align]
[align=left]4) Disconnect the leadwire from the turntable motor[/align]
[align=left]terminals.[/align]
[align=left]5) Remove the screw securing the turntable motor to[/align]
[align=left]the oven cavity assembly.[/align]
[align=left]6) After repairing the motor, rotate the removed[/align]
[align=left]turntable motor cover.[/align]
[align=left]7) Fit the turntable motor cover's projecting part to the[/align]
[align=left]base plate slit.[/align]
[align=left]NOTE:[/align]
[align=left]1. Remove the wire lead from the turntable motor[/align]
[align=left]VERY CAREFULLY.[/align]
[align=left]2. Be sure to grasp the connector, not the wires,[/align]
[align=left]when removing.[/align]
Welcome, remember parts can only be bought thru L.G. Electronics thru an authorized service company.
