ASKO Dishwasher Model #D3120
SANTA
  • SANTA
  • appl.tech.29501
Thanks for the manual. This dishwasher would fill with water and then do nothing. To make a long story short, when I put it in service mode and switched from flow meter fill to timed fill it worked again.
