samsung sxs #rs2630sh
Guest
  • Replies 10
  • philcheck
thanks regus. you gave me the manual before but only half of it downloaded.i'm trying to find at what temp does the defrost stat open. origional was stuck closed ordered new one and its closed at room temp as well. i don't get it.
Defrost Terminator should open at 59F
this is a different manual ..
each manual is about 4 or 5 MB
may take a while to download
take a close look at the Terminals of your Defrost Heater ...
thanks reg. got it downloaded.if it opens at 59 degrees.it should open at the room temp i tested it in. the amnual says bimetal closed at 104 f opens at 140 f. what is that about?. i get 40 ohms on the heaters through the main board. but i will look at the ends of the heaters. i'm going to replace defrost stat and defrost sensor first.also i'll try force defrost to make sure the heaters come on, but that doesn't mean they'll come on automatically though. i want to rule out all before looking at replacing the board.
[user=28826]mrfixit2[/user] wrote:
... says bimetal closed at 104 f opens at 140 f. what is that about?.
I see that now, although, right above that it mentions the Defrost Thermosatat 59F
i know ,its confusing, not opening till 140 f explains why i couldn't get it to open even with a hair dryer. but i still don't get what closed at 104 f means?.i'm beginning to dislike this fridge.i don't go back till tuesday, that will give me time to study the manual.btw the stat is one of those ones that is inside a see through plastic envelope type thing.
once it opens at 140F, it won't close again till it cools to 104F
  • 7 years later...
The link or attachment for this service manual is bad. Can you please repost the service manual?
Fast Track is already in the Downloads. Watch the video on how to search the Files section and you’ll find it.
