The days of Monkey Boy Service Calls are over...
Click here to check out our fun short course and learn how to get the most out of Appliantology.
scooter
Gibson Fridge Trips Breaker
8 posts in this topic
Have Gibson refrigerator (RT17F7DP38).  After being moved about 20 miles, the unit was plugged in and would trip GFIC breaker when defrost cycle was reached.  Manually cycled the defrost timer about 10 times, which tripped the GFIC each time.
After cycling it 10 times, I set the defrost timer to a position just past the defrost cycle.  The unit ran for about an hour and was cool.  I manually cycled the defrost timer and the unit did not trip the breaker when the defrost cycle was reached.
Anyone have an idea as to why it was tripping the breaker and now is not?
Weak GFIC breaker. Try an extension cord to another circuit and test.
I will give that a try, but this same circuit was just recently used to power a 15 Amp miter saw (which has a very hard start) with no issues.
Just curious as to why it tripped sometimes and not others when the timer hit the defrost cycle.
Thanks.
[user=950]GLC[/user] wrote:
Weak GFCI breaker. Try an extension cord to another circuit and test.
I just installed a new 20A GFCI. Frige trips the new GFCI. Test a non-GFCI circuit and it fridge did not trip it.
What is causing the frige to trip the GFCI?
I have had the exact same thing happen to me before.  I have no idea what the amp draw is going on with the frig but if you have access to amp meter you may want to check amps in run and then in defrost.  In defrost amps usually run somewhere in the neighborhood of 3.5 or so.  And that is where you are saying it is tripping?  Only in defrost?  If I were there that is what I would look at first.  How many amps in the defrost cycle.  The one that I went on was a week breaker.  Other than that maybe some one else here can point you in another direction.
Remember guys, what is the GFIC -- (Ground Fault Interupter Circuit). It not the amps that is tripping the GFIC, it's the ground fault.
Here's how you can verify this: Get one of those handy adapters that convert a 3prong grouded plug to a two prong plug, (Make sure the adapter that you use has the little ground lug that sticks out the side that can be screwed to the center socket screw.
Now, plug your power cord with the adapter on it into the GFIC plug, DO NOT hook up the ground lug. Now if you put the frig into defrost I can garantee you that it won't trip the GFIC or the circuit breaker in the fuse box.
Now to actually verify, you will need to use your meter and check for AC voltage from the ground lug adapter of the 3-prong plug adapter to the ground hole of the GFIC. I can almost assure you that you are going to be seeing a reading of a couple of volts. This leaking voltage to ground is tripping the GFIC -- It's a ground fault.
Now, go find where the leakage is occuring ----- GOOD LUCK.....
It is my understanding Refrigerators are not to be run on these anyway, best to plug into a regular outlet.
I read this on a few sites after a quick google.  Also, when I plugged the frige into a non-GCIC outlet, it never tripped a circuit breaker in the fuse box.
If there is no voltage on the ground, I will probably convert the outlet to a standard outlet or run a dedicated circuit.
Thanks to all that have helped out.
