Samsung Ref. Mod# RFG297AABP
Rodgers Appl.
  • Rodgers Appl.
No gotty, compadre. Best I can do is a service bulletin on the ice system. Would that help?
Yes that would help.  They say that the ice maker isn't working and if they put baught ice in the bin, it sort of melts together.  I'm thinking it must not be cold enough for the ice maker to cycle.
