possom767
Maytag smooth top range short
4 posts in this topic
Hello, I'm new here and decided to give you a try because I'm perfectly capable of doing what the repair men do, and I want to save some money. I have a Maytag 5 burner range that we got over the weekend at an auction. Came home, plugged it in and started turning on all the burners and warming center. Before I could even set the clock, or figure out how to use the oven, I saw a spark come out from behind the clock display/oven control unit. Now everything else still works but I have no oven. I checked for a fuse but didn't recognize anything that looked like one. We are having an electrician buddy check the 220 wiring for fault. What do I need and how do I do to get the oven working?
Going to need the model and serial numbers before anyone can help you probably....
Sorry, I forgot. It's a Maytag Model#MER5770BHW  Serial#13956803AG
Pull the bottom drawer out and look for a little plastic envelope taped to the side-- it has the wiring diagram, You're gonna need to get your electrician friend back out to track down a wiring problem in the range.
