mthompson
magic chef gas stove ignition problems - model number 3468xrw
8 posts in this topic
Hello,
I have a Magic Chef gas range - model number 3468xrw- that is having ignitor problems. The two left ignitors spark, but the right ones do not. I have switched the ignitors, left to right, and get the same result - no spark on the right, spark on the left.
What's going wrong?
mthompson
You mean you just switched the ceramic electrodes?
Try switching the wires that that connect to them. I think you'll find that you need a new spark module.
Hello,
How do I go about switching the wires? Where do I access them? The stovetop is sealed.
thanks, MT
How did you switch the electrodes? The ignition wires are attached to them!
It's possible you have a bad ignitor switch.  It could be fouled up with grease or just a bad connection.  It could be bad.  Each burner valve has a switch.  You can drop the manifold panel and take a look at them.  The switch part number is 7403p279-60.  You can get them here...Ron
Thanks for helping out, Ron.
mt, here's the link to the switches Ron is talking about, CLICK HERE.
Samurai's Ichiban Law of Appliance Repair, "Never replace a part unless you have proof that the part is bad."
On this one, you turn and lift each sealed burner. Underneath them, you'll see a wire that attaches to the electrodes. You'll also see two Phillips screws that'll have to come out-- same with each burner. Then the top can be lifted like a car hood.
Or you can save yourself some hassle and just replace spark module.
