Matt_In_Michigan
Kenmore Elite Range Model No 79099013101
6 posts in this topic
So, my recalled Figgindaire-in Kenmore Elite Clothing-bake element flamed out.  I have ordered the replacement element.  The old element shorted and took out the connector on one end.
How do I safely power my stove back on, I don't want to waste away :D, without risking shorting something else out?  All I have are the 2 wires with the connectors on the ends?
Thanks in advance,
Matt
could just install it.
the shorted Element may have already taken out the Oven Controller ...  :violin:
790.99013101
Owner Guide:
316257910en
Wiring Diagram:
316255122
Installation Instructions:
316259200en
Parts Manual:
5995378501
Tech Data:
316259133en
Unfortunately when it shorted, it burnt the terminal off one end of the element.  I have an element with only 1 terminal.
you have to buy another new element...next time try unplugging the range or turning the breaker off. if the wire end was also damaged make sure you replace it with a "high temp" terminal crimped securely (not just smashed with pliers).
I have the new element on order, should be here tomorrow-ish.  I've never had any other problems replacing elements.  However, most of those were much older models.
Why is the element live, even when there's not signal for heat?  To say that I was surprised by that, would be an understatement.  My shorts speak for themselves.  :yikes:
1 side of the bake and the broil is wired directly to line voltage.... you just got lucky the other times ;)
