Bosch Diswasher Model SHX46A05UC / 30
5 replies to this topic
#1 JW_novice
JW_novice
  • 5 posts
Posted 18 October 2010 - 09:19 AM
Regular cycle takes 4+ hours. Looks like from other posts it is thermostat, heater or controller?? Looking for the diagnostic sequence and codes for this particular model. Help!  (and thanks).
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 18 October 2010 - 09:28 AM
service manual link PM'd   12 MB
#3 JW_novice
JW_novice
  • 5 posts
Posted 19 October 2010 - 08:53 AM
Service book was a great help - thanks!
So, I found the burnt solder on the board, just like the examples (obviously a latent defect). Question is now: do I re-solder or try to have it replaced under warranty.?Looks like the electronics are covered by 5 years (installed unit in 2006). Looks like an easy fix, but if it doesn't work, I don't want to void my warranty.
On the other side, if I have to pay a tech hundreds to come and verify what I already know, it really may not be worth it.
I am including a pic of the burned board. Any thoughts would be appreciated!
-end-
    Shōgun
  • Master Samurai Tech
  • 30,954 posts
Posted 19 October 2010 - 05:03 PM
If you're comfortable soldering, you can try your hand at the repair, nothing to lose really. I've done this repair many times==> http://fixitnow.com/...mplete-a-cycle/
Some basic info on how to solder==> http://fixitnow.com/...pliance-repair/
#5 JW_novice
JW_novice
  • 5 posts
Posted 20 October 2010 - 06:13 AM
OK, did the solder and have run 2 cycles through - so far everything appears to be good. Took less than 2 hours each time. No expensive service call, no more expensive controller board replacement.
Thanks again!
    Shōgun
  • 30,954 posts
Posted 20 October 2010 - 06:22 AM
Great job!
