Guest Dr. Dave
Error Code F1 on a JennAir Range
2 posts in this topic
I'm receiving an error code F1 on the front panel of my Jenn Air Model SVE47100B, Serial #17054877WS.
The error code comes on when the oven is hot and I can't turn on the oven again (to bake) until  given at least an hour or more for the oven to cool.
Do I replace the touchpad and control unit, or the clock unit.  (the clock runs fine, the oven cleans and broils.  I just can't bake).  If it is the touchpad, what holds it down?  Double stick tape, glue, or just the mounting screws?
Good Samurai, any help would be appreciated.
Dave
druckerman@cox.net
Usually, this is a bad sensor (item 12). Ohm it out to be sure. Also, check the sensor harness connector on the ERC. If the sensor is bad, get a new one here.
