Boss07Hog Posted October 22, 2010 Share Posted October 22, 2010 I am having a water inlet problem. The hot water comes in just fine but the cold water just kind of trickles in. Just finished replacing the water inlet valve assembly and is still doing the same exact thing. Was wondering if I could get a copy of the service manual and any expert advice on where to go from here. Thanks.OK, after seeing another post how to go into svc mode, found 2 errors. One said something about an inverter problem and another about a communication error between the main pcb and the inverter pcb. Didn't realize they would clear through the process and I didn't write them down to be exact on the message. Link to comment Share on other sites More sharing options...
RegUS_PatOff Posted October 22, 2010 Share Posted October 22, 2010 GE WPGT9350 Harmony Washer built by LG The water valves receive power from the inverter.31-9103 link PM'd Link to comment Share on other sites More sharing options...
Boss07Hog Posted October 22, 2010 Author Share Posted October 22, 2010 I assume the inverter is part of the main PCB correct? Thanks for the manual, greatly appreciated. Link to comment Share on other sites More sharing options...
RegUS_PatOff Posted October 22, 2010 Share Posted October 22, 2010 separate board, as shown in the service manual Link to comment Share on other sites More sharing options...
Boss07Hog Posted October 22, 2010 Author Share Posted October 22, 2010 Ummmmm...LMAO. Found the problem. Never thought a hose could go bad. Guess the barb inside the hose broke and turned sidways making almost a complete blockage on the cold water side. Ran a copper grounding wire through the hose and turned it straight again. Everything works perfect now. Feel like an idiot, I know better, KISS is something I always practice but forgot this time.Thanks for your help again Link to comment Share on other sites More sharing options...
RegUS_PatOff Posted October 22, 2010 Share Posted October 22, 2010 [user=71849]Boss07Hog[/user] wrote: Ummmmm...LMAO. Link to comment Share on other sites More sharing options...
Boss07Hog Posted October 22, 2010 Author Share Posted October 22, 2010 Yeah I know...kicked myself is the a$$ for it. Funny thing is I am an electronic tech....so I had the schematic out and meter and tested almost every single circuit on the inverter and main pcb. Was going at it for a couple hours. Link to comment Share on other sites More sharing options...
