JUNK GE GSS20IEMBWW new motherboard
28 replies to this topic
#21 Poobah
Poobah
  • Appliantologist
  • 1,485 posts
Posted 25 July 2007 - 08:00 AM
If you notice the diagram that Jabko has posted you will see the thermistor value chart, this shows the resistance value the thermistor should have at a particular temp.  Having already changed the safety and the heater there is only the thermistor and the board left.  The thermistor is the lkely culprit as already stated, the older ones are prominent for going bad.  I have had them show to be in spec and still not work right, so I change them on every job I do automatically (besides there in-expensive anyway). Trouble is there is no real way (I know of) to test the board. Change the thermistor and keep an eye on it if it does freeze up you will be changing the board,  if not then you GTG......good  luck ....check back
This is the DAY that the LORD has made, REJOICE and be glad in it.....
#22 mike1148
mike1148
    Ikkō-ikki
  • 42 posts
Posted 25 July 2007 - 08:27 AM
Guess no one knows where i could find a tech manual on GE sxs?
THank you  for all your Help!!! Sure is nice to talk with people that has the same oppinion of ge as i do... thanks again
#23 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 25 July 2007 - 09:13 AM
The Samurai has them on the X-drive for us techs, if you will wait for him to get in from his Fix-it-Do'ing this evening or tomorrow, he might be so inclined to post a link to a manual for you, we cannot do this, only the Samurai..;)
#24 mike1148
mike1148
    Ikkō-ikki
  • 42 posts
Posted 25 July 2007 - 01:05 PM
I sure thank all you guys for  the quick responses and great info.... best forum I ever been too... I figured it would be days for i got a response.
thanks again! Mike Johnson
#25 dp_sos
dp_sos
  • 4 posts
Posted 04 August 2009 - 08:04 AM
Jabko,
Would it be possible for you to post or send me the tech sheet you developed?  It would be most appreciated!  --Duc
#26 jabko
jabko
    Yamabushi
  • Appliantologist
  • 88 posts
Posted 04 August 2009 - 08:38 AM
Click on the link below, or do a google search for a wr55x10656 and click on pictures to search and it comes up on the first page, this tech sheet is getting old and the board on the newer unit has additional plugs, the board the sheet was on a wr55x10552, good luck email if you need assistance with a problem, John
http://images.google...0656&hl=en&um=1
#27 elmonducky
elmonducky
    Sōhei
  • 225 posts
  • Flavorite Brew:Cabernet Sauvignon
Posted 04 August 2009 - 03:57 PM
just read this, any chance of getting a copy of your "cheat sheet"?????
#28 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 04 August 2009 - 05:28 PM
did you click on the thumbnail in the above link ?
#29 dp_sos
dp_sos
  • 4 posts
Posted 05 August 2009 - 08:41 AM
Mucho Gracias, Jabko!  The diagram looks very informative.  I have a different model, GE GSS23SGSBSS, but I hope the schematic is still applicable.   Thanks again!  -- Duc
