Maytag top load washer mav3855aww seris 10
#1
Posted 06 November 2010 - 01:56 PM
#2
Posted 09 November 2010 - 07:39 AM
Allahu Akbar!
#3
Posted 10 November 2010 - 07:04 PM
#4
Posted 10 November 2010 - 07:22 PM
Examine the Drain Hose for obstruction---such as a *coin* or *large coat button*.
A round-shaped piece of debris can cause erratic drain (swivels open & then shut).
Inspect the Drain Pump and the Tub-to-Drain-Pump HOSE as well.
If no debris is found...
Remove the AGITATOR & LAUNDRY BASKET. Inspect the WATER TANK / TUB for an article of clothing that swirls around in the tank during drain & causes irregular draining of water by blocking the hole at the bottom of the water tank.
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#5
Posted 10 November 2010 - 09:19 PM
#6
Posted 11 November 2010 - 06:11 AM
#7
Posted 11 November 2010 - 11:55 AM
If that checks out remove the drain hose from the pump again and insert a screwdriver in the pump outlet to stop the impeller from turning and see if you can turn the pump pulley easily (don't get crazy with it) just trying to see if the impeller may be seperating from the pulley.
www.eliteapplianceservice.org
#8
Posted 11 November 2010 - 11:58 AM
