  • Announcements
nowwhatbroke
Maytag dishwasher
8 posts in this topic
My Maytag Model#DWU9962AAB dishwasher recently began to stop in mid-cycle and display "blocked drain" on the face panel.  I am able to get the cycle to complete if I open and close the door; however no luck in finding the cause of the evil.  I have already checked for pieces of ? where the water drains out in the bottom of the tub.  I have also removed and blown out the drain hose to be sure it is clear.  Still, the evil persists.  Do I need to take the pump apart next?
Pages from manual and schematic attached.
DWU9962AAB.pdf
Hellllooooo......
Anyone with an idea?????
Whoa! This one slipped by. And you even posted a cool pdf attachment. Thanks for being persistent.
Let's start with the basics. First step is to tear into the pump from inside the diswasher and see if you can find any out-of-place gookus that might be causing an obstruction.
did you recently change out the garbage disposal? if you didnt remove the knockout the didshwasher wont act right ,just covering all bases
I took everything apart, down to the point where I was looking at the perforated plate where the water goes out to the pump.  I did find a couple of pieces of chopped-up plastic (like Ziploc bag thickness) floating around; but they weren't big enough to block the outlet too badly.  After reassembling, I ran a rinse cycle and it was OK.  Everything drained.  Then I ran a regular wash cycle and again got the BLOCKED DRAIN warnings, so I opened and closed the door to reset it a couple of times to complete the wash cycle.
I installed the disposal over a year ago.  The knockout was knocked-out.
Thanx
Does anyone know how this machine determines that it has a blockage?  What kind of sensor does it use?
I haven't worked on a Maytag like this one so I'm only going on general ideas from looking at the parts breakdown and wiring diagram.
This is a computer controlled unit, and there is a part on the wiring diagram called "Wash Process Sensor" and also a "Rinse-Aid Sensor".
Part ref# 32 is called a "Sensor Cluster" I don't know if this contains both of the above sensors or not. This sensor may be something to do with or actually the problem. Don't just go replacing it though becuase I'm not totally sure, let someone else that knows the operation of this part guide you further along in your repair.
There is also the possiblity that the controller board senses the amp draw of the motor and if all the water hasn't been drained in the alotted time the motor will still be pulling a higher amperage telling the computer that the drain is block.
Don't know how strong the water stream is coming out the drain but when you tore the pump down to the screen, you didn't get down to the lowest bottom impeller which is the drain impeller. There is the possiblity that something has damaged the drain impeller so it's not draining fast enough.
