Poor Cooling - Jenn Air JSD2789AEB
28 replies to this topic
#21 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,703 posts
Posted 16 January 2006 - 06:26 PM
Now is the time we must rest our gaze upon the evaporator coil itself and its attendant fan. You are our eyes; tell us what you see.
#22 Lurker_Texas Dukester_*
  • Lurking at the Threshold
Posted 16 January 2006 - 07:07 PM
Where are we looking, and what are we looking for?
#23 Lurker_Texas Dukester_*
Posted 16 January 2006 - 09:23 PM
We are gazing upon the evaporator coil itself. Its attendant fan is operating finely, and once the cover was removed from the assembly, air indeed "gushes" into the beer box, even with the ice box door closed.
The coil itself looks like a miniature cold weather stalagmite experiment, as it is covered with fuzzy 'ice' as is the cover surrounding it. There do not appear to be any blockages above the fan, although two round tubes to the right of the fan were blocked - one partially, the other completely - by snow. These are now clear (I could only push the snow in, to wherever the tubes lead. It seems like a fair-sized open area). Herself, the wifely one, wonders if the coil and casing should have so much frozen material upon them.
The temperature, which was around 0º just the other day, is now hovering between 30-40º although this is after the ice box door has been open long enough for us to remove all frozen items and transport them to the outdoor freezer (with the door remaining open in the meanwhile), and then removing the inner shelves and panels and gazing upon their countenances for some time. I am awaiting a more favorable return after some minutes ....
It has dropped 10º in the past 15 minutes. Will know more in the morning.
#24 Lurker_Texas Dukester_*
Posted 17 January 2006 - 04:01 AM
Oh Singular Master!
The pebble in your hand is a new $100 evaporator coil!
The temperature in the ice box is over 25º and in the beer box, over 50º!
Please reward me with your wisdom!
#25 Samurai Appliance Repair Man
    Shōgun
  • 30,703 posts
Posted 17 January 2006 - 02:06 PM
This is a defrost system failure: ADC board, defrost heater, defrost limiter. You'll need to test each component to determine which one is the bad actor.
#26 The Garmin Man
The Garmin Man
  • 4 posts
Posted 09 July 2006 - 11:11 AM
O wise one, It has been many days since we have last communicated.  It seems as if the freezer coils continually ice up. Everything is clean and there are no obstructions.  I find myself thawing out the coils about every two weeks.  I do not believe that the coils are getting defrosted.  What items must I check to insure proper operation?  Your wisdom as always is appreciated.:yikes:
#27 Samurai Appliance Repair Man
    Shōgun
  • 30,703 posts
Posted 09 July 2006 - 06:23 PM
You have returned, and with a different problem on your fridge. This will be a defrost system problem, usually the ADC board, but easy enough to verify. If I were on the call, I'd tear apart the freezer ('cuz I'd have to defrost it anyway) and check the heater and defrost terminator for continuity. If they check out, then I'd slap in a new ADC board and warranty the repair for a year. No call backs yet! :)
#28 The Garmin Man
The Garmin Man
  • 4 posts
Posted 10 July 2006 - 07:59 PM
Oh Wise One, I have checked the items you described and they show continuity.  I am leaning toward the defrost board.  Before I tear into neverland, could you briefly describe where the board would be located and how best to get to it?  On another note, I have read your plea for beer fund replenishment and have authorized my financial institution to send you a small token of my gratitude.  I also see that you like to wander the mountains with your german companion.  We do the same here in Oregon.  We also have a german companion plus 3 wild ones from Siberia.  Should you ever need assistance with a Garmin GPS please do not hesitate to ask.  As always, we appreciate your wisdom and the fact that you share it!
#29 Samurai Appliance Repair Man
    Shōgun
  • 30,703 posts
Posted 11 July 2006 - 03:49 AM
The ADC board is inside the beer compartment, up top, right at the ceiling. Remove the top shelf inside the beer compartment so you can stick your head inside and turn it to the sky. The ADC control is in the that top-most control compartment, right hand side. Start by unplugging the refrigerator.
There are two sets of screws,a Phillips pair, and another 1/4" pair, toward the front that need to be removed. There's also a pair of 1/4" screws on the back way that need to come out. This diagram might illustrate it better.
Now, here's the tricky part. To pull the control plate tray out, you need to pull the tray down and toward you at the same time. It's tricky until you get the hang of it. Remember: finesse, not force. You're dealing with cheap plastic-- if you force it too much, it'll break.
The details may vary slightly among models but improvise, adapt and ye shall overcome.
