Viking VCRB304 Refrigerator Error Codes
8 replies to this topic
#1 JMC2010
JMC2010
  • 3 posts
Posted 13 November 2010 - 10:52 AM
Hi guys,
We have a 30" fridge, no freezer. Does anyone know what the beep codes are for this fridge?
We had a few people come out. First guy said it was the door switch, 5 beeps still happen. 2nd guy said it was the control  board. I replaced that last night, still the 5 beeps.  Any help would be great!
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,903 posts
  • Flavorite Brew:Killians Red
Posted 13 November 2010 - 02:24 PM
5 quick beeps is the signal of a bad thermistor....
since this is a fridge only(no freezer) there is also a power supply board that fools the unit into thinking it also has a freezer (both use the same control board)
if this fails, it can also cause the 5 beeps; i know this cause i already had this exact issue drive me nucking futs and indeed it was the power supply....
no way to test the power supply but if the thermistor and wiring harness check good thats the problem.not sure what the resistance should be exactly on the thermistor at room temperature but i will try to find out later (unless reg beats me to it LOL)
#3 JMC2010
JMC2010
  • 3 posts
Posted 13 November 2010 - 05:05 PM
Thanks for the reply.
BTW the part I replaced was 005319-000 POWER CONTROL BOARD. That is what the 2nd tech was going to replace. So I picked one up and did it my self.
#4 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,903 posts
Posted 14 November 2010 - 04:31 AM
not sure what that part you replaced is... it is a good # but the part lookup i use (vikings ) sez the power suppy board is part #  PE970608
located in the compressor area, to the right side of the compartment.
can you attach a photo of the board you replaced?
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 14 November 2010 - 04:46 AM
this one ?
005319-000 POWER CONTROL BOARD ASM
#6 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,903 posts
Posted 14 November 2010 - 05:17 AM
yeah, that is not the power supply board i am referring to...that is the "high voltage" board.
if this looks like the part you replaced, you need to check in to the other part # i gave you as it is the one that could cause the 5 beeps...
#7 JMC2010
JMC2010
  • 3 posts
Posted 14 November 2010 - 06:28 AM
Great! Thanks for the help guys. I'll will update on the progress.
Thanks again!!
@ [user=3641]RegUS_PatOff[/user]
That is the part I checked out. Well the part the 2nd tech said needed to be replaced.
#8 RegUS_PatOff
  • 33,588 posts
Posted 14 November 2010 - 07:10 AM
PE970608 POWER SUPPLY
#9 jim1872003
jim1872003
    Yamabushi
  • Appliantologist
  • 95 posts
Posted 05 March 2012 - 02:24 AM
Check out how to program these models. The freezer setting always has to be on 9!
