charles
kitchen
6 posts in this topic
I am pretty sure I have a problem with the spark module.  The ignitors always spark.  Not all the burners at one time but one burner at a time and not always the same burner.  Question is how to get to the spark module.  Does the whole unit have to come out of the countertop to work on.  If so do I need to raise up a litte and leave the gas line attached or do I need to disconnect the gas.
Model No. is CVG-2420.  I looked at the top of the unit and do not see how I could get in from the top.  The area around the control knobs seems to be sealed with a rubber gasket so I assumed I had to go from the bottom.  Maybe this is not a do it yourself project?
Jenn Air Gas Cooktop
Do not find a model number so we can pull up a breakdown on this unit...
I double checked on the unit and the care manual.  Both have the model as CVG2420W, I assume W is for white.  It is an Expressions Sealed Gas Downdraft Cooktop 1994.  Serial number is 13744074KU.
Direct link to your spark module, CLICK HERE.
