Whirlpool Duet F-21 Error Code
7 replies to this topic
#1 lnsmktg
lnsmktg
  • 3 posts
  • Flavorite Brew:Bud Lite
Posted 26 November 2010 - 03:32 PM
Washing Machine will not drain. I am getting the F-21 error code. I followed the instructions and cleaned out the filter which was pretty clogged. The washer worked for a few loads and the again F-21 code. I ran diagnostics and it pointed to the pressure switch/water level switch I replace it and again it worked for 5 to six loads. I just put one coat in to wash and F-21 again and it will not drain. Any other ideas? Its is a whirlpool duet model number WFW8500SR00
#2 Trying to help
Trying to help
  • 2,464 posts
Posted 26 November 2010 - 09:48 PM
The F-21 is along drain time. If you put your unit into drain, and have 120VAC to the pump, and no water is going out. Then you either have an obstruction in the pump or drain line, or you have stripped out the pump impeller. Do you have a meter to check and see if you are getting voltage to your pump??
Edited by Trying to help, 26 November 2010 - 09:50 PM.
If we saved YOU Beer $$ today, please make a donation to our beer fund by clicking the link below to help keep this site going. I charge $135.95 PLUS PARTS to do this repair!$! http://fixitnow.com/beerfund.htm
#3 lnsmktg
lnsmktg
  • 3 posts
Posted 27 November 2010 - 09:36 AM
Yes I have a meter. I hear the pump come on. Why would it work and then not work? What do I do with the meter?
#4 RegUS_PatOff
  • 30,708 posts
Posted 27 November 2010 - 10:09 AM
... What do I do with the meter?...
... have 120VAC to the pump,
... if you are getting voltage to your pump??
  • 24,721 posts
Posted 27 November 2010 - 11:30 AM
Could be losing power; something could be caught in the impeller; the pump itself could be going bad.
#6 Trying to help
Trying to help
  • 2,464 posts
Posted 27 November 2010 - 12:53 PM
"If you put your unit into drain, and have 120VAC to the pump, and no water is going out. Then you either have an obstruction in the pump or drain line, or you have stripped out the pump impeller"
If you have 120VAC to it, and it is not draining, then either the impeller is stripped (can catch now and then for a load but will eventually completely strip out) or there is something blocking the water (kink in line, obstruction in line or to pump, could be sock or a coin acting like a butterfly valve. If it has power, and you hear it pumping but nothing is coming out you are either stripped or restricted in some way.
#7 lnsmktg
lnsmktg
  • 3 posts
Posted 27 November 2010 - 03:58 PM
I am getting power and the pump is making all the normal noises. I removed the pump and the impeller slid right out I noticed there was dirty water inside the impeller shaft area. Is that normal?
#8 kdog
    RoughShod
  • 7,433 posts
Posted 27 November 2010 - 05:10 PM
If the small Impeller slides off of the motor shaft, that's your pumpimg problem :huh:
click link
Edited by kdog, 27 November 2010 - 05:13 PM.
