Troubleshoot modern appliances with confidenceā€¦
Charles Wilson
kenmore dishwasher 665.110733420
6 posts in this topic
Our dishwasher is not running properly. The motor will go when I push the start button but automatically reverts to canceling and draining although it does not need to drain. It will continue for a certain period of time( 5min - 10min)then turns off automatically. In other words when I push start the cancel/drain light illuminates instead. Can you help?
The dishwasher is 6 years old.
I've read forum archives and I not sure if the thermal unit, control panel or the motor is the issue.
Tried latching the door firmly and that doesn't seem to be the problem.
FYI: all lights will NOT illuminate when pressed except;
Cycles:
- Heavy Wash light and Wash light will illuminate when pressed.
- Quick Rinse light and Wash light will illuminate when pressed.
Options:
- Air Dry light and Wash light will illuminate when pressed.
Any help or advice would be greatly appreciated,
Thanks Charles
Check that model number again, Budrow.
Thanks for replying so quickly, the use and care guide booklet says Models: 665.11073342, 665.11073349
On the side of the door, the sticker indicates:
Model 665.110733420
Ser FR0604341
Stock No 73342
Type No 280-2
I realize the extra (zero)0 on the model number, but I wanted to accurately write down the numbers.
(ps I double checked three times)
Thanks Charles
665.110733420
I can't find any parts info, but ServiceMatters shows
Tech Sheet 8533345
similar to DU940 , ect ..
665.110733420 Tech Sheet
Sear repair came did $100 diagnostic - the problem is the electronic control/computer panel #261108530929.
He took the original one out and put in the new one and the dishwasher ran perfectly. Only with the labor and price of the new part, the total would be $436.00. The technician said the part is $200.00 itself.
Do you have this computer panel? and what is the price for the unit?
Charles
Click on link
