Whirlpool Accubake oven problems MOD SF367LXSS
30 replies to this topic
#21 MVP82
MVP82
  • 13 posts
  • Flavorite Brew:As far as domestic beer goes I gotta say "Coors Light"
Posted 29 November 2010 - 11:10 PM
I ran a ground wire. Didn't work. However, before doing that I did run the diagnostic test utitizing the cancel/off cancel/off start method and I did come up with a diagnostic code of E646. Could I have a gas distribution valve issue?
#22 Samurai Appliance Repair Man
  • 24,207 posts
Posted 29 November 2010 - 11:11 PM
The tech sheet with your range would have that error code. Do you have that?
#23 MVP82
MVP82
  • 13 posts
Posted 29 November 2010 - 11:29 PM
I don't have it but I did some searching online and found this? It's not the same model though...
Edited by Samurai Appliance Repair Man, 29 November 2010 - 11:55 PM.
removed link
#24 Samurai Appliance Repair Man
  • 24,207 posts
Posted 29 November 2010 - 11:56 PM
Yeah, the link didn't help.
Did you remove the pots drawer and look in that cavity? Also, underneath the drawer itself. Back of the range is another hiding place.
#25 MVP82
MVP82
  • 13 posts
Posted 30 November 2010 - 12:17 AM
Sorry about the link I should have put two and two together. I did indeed remove the pots drawer and all wires appear to be in good working order. I guess I just have to figure out what the fault code E646 is for first and then go from there.
#26 Samurai Appliance Repair Man
  • 24,207 posts
Posted 30 November 2010 - 12:21 AM
No problem on the link.
Here's a tech sheet for a Whirlpool DSI range, not sure it applies to yours. Look at the diagnostic section and see if you can run diagnostic mode. Also note that there is no E646 error code.
http://dl.dropbox.co...9761386 (1).pdf
Edited by Samurai Appliance Repair Man, 30 November 2010 - 12:34 AM.
Forgot to add download link!
#27 MVP82
MVP82
  • 13 posts
Posted 30 November 2010 - 12:30 AM
Am I missing the tech sheet? Lol
#28 Samurai Appliance Repair Man
  • 24,207 posts
Posted 30 November 2010 - 12:33 AM
Maybe you're just not finding it. Maybe it was "borrowed" by the last guy who worked on the range. Every range ships with one. It's the only place that lists the error codes for the range. Even the service manual doesn't list em.
#29 Samurai Appliance Repair Man
  • 24,207 posts
Posted 30 November 2010 - 12:34 AM
Added the download link that I forgot in my earlier post! :blush:
#30 MVP82
MVP82
  • 13 posts
Posted 30 November 2010 - 12:51 AM
Cool thanks. :thumbs:
#31 RegUS_PatOff
  • 30,192 posts
Posted 30 November 2010 - 01:43 AM
SF367LXSS Tech Sheet - 9762973
but error codes are F1 E0 , etc ...
