  • Announcements
MrHandyinNH
Gas Range Spark Module needed for Rare Sterling Cooktop
6 posts in this topic
Hello Mr. Samurai! I am once again requesting your advice: My Sterling brand, 5 burner, gas cooktop was new in 1993. The plate says "New World Domestic Appliances, LTd", Warrington, England. Model GCT360/5D, "Engineering Number": WA5525NOO. Serial Number FG0002 (Serial Number 2?!) The ignition module gets120V, the switches appear ok. It was intermittent for years, it would not work for a week, then mysteriously work again. All connections seem ok. The module inside says : Ignition Module model 0950 10 02 120V 60Hz. Brand stamp looks like AGA ? AGC? maybe. (Same logo as seen in top diagram shown here: http://www.applianceaid.com/images/typical-sparkmodual-wiring.JPG) Google shows the manufacturer as in UK and not selling to USA! I'm wondering if I bought the only one they ever sold in the US?! The igniters are the little ceramic "spark plug style" at each burner. Can anyone suggest a substitute ignition box? Thank you in advance for your help!
Howdy, neighbor. Since all spark modules operate the same way, your task really boils down to finding one the right number of ports. Does your spark module have four output ports, mas shown in the diagram you linked?
Greetings Mr. Samurai! My cooktop has 5 burners, so I need a module with at least 5 inputs. Got one my size?
"C"
Right, I got the 5 burners part, but often, two burners are ganged together, resulting in a mere 3-port output (in your case: 2 + 2 + 1).
If you're saying that your present spark module really does have 5 individual output ports, then I don't know of any replacements for this.
They all fire at once, i.e. I've observed them all firing, when lighting 1 burner. So maybe all I need is a singel output? (Each sparker plugs into its own connector on the module, and there are more ports available, but maybe it's just one output...)
Had any frost up there in Otterville yet?
Ahh, in that case, you can probably adapt this spark module to work.
We keep hoping for the frost to get here and kill some of these damn skeeters and knock out some of this fall pollen! Ahh-CHOO!
