maytag neptune DO error MAH5500BWW
7 replies to this topic
#1 user444
user444
  • 4 posts
  • Flavorite Brew:tea
Posted 01 December 2010 - 02:22 PM
Ok I get the DO error still after changing out the whole latch assembly and Control board all new parts, still have this DO error, I will tell you this unit had been working fine other then the bearings were bad and I changed them, reinstalled everything back and stuck with this dreaded DO error, help.
    Shōgun
  • Master Samurai Tech
  • 30,622 posts
Posted 01 December 2010 - 03:52 PM
Did the DO error only pop up after your changed the drum bearings?
#3 user444
user444
  • 4 posts
Posted 01 December 2010 - 04:33 PM
yes
    Shōgun
  • 30,622 posts
Posted 01 December 2010 - 04:35 PM
Awwite, then the most likely scenario is that one of the switches isn't wired correctly or a loose harness connector to the door latch. Use the schematic in the tech sheet to double and triple check your wiring of the door latch assembly.
#5 user444
user444
  • 4 posts
Posted 01 December 2010 - 04:40 PM
hmm ok i apperiacte your suggestions Ive ohm'd everthing back to the boards and they all seem good, I have a post running in just answer too on this problem which will explain more of some of the things Ive done
Edited by Samurai Appliance Repair Man, 01 December 2010 - 04:41 PM.
Deleted link
    Shōgun
  • 30,622 posts
Posted 01 December 2010 - 04:43 PM
No, you have to compare the wiring on the schematic with the physical location on the latch assembly. A common mistake is to switch a wire with the NO and Common terminals on a microswitch, for example. That's just an example. You need to look at every wire. There are no short cuts, no silver bullets.
#7 user444
user444
  • 4 posts
Posted 01 December 2010 - 05:21 PM
I will do this again, i do agree, I can tell you though under the Diagnos. menu I can operate the door lock and door open correctly, I really dont have much left to change other then the Motor Control board, on the connections though they really only go one way, and when I do a test on the points where they connect to the board the sence and input I show my 24 vdc and open and close as the door is used, But I didnt pay attention though as too if ITS suppose to be open or closed as it should tell me in the schematic, but would the test I mention kinda tell me anyway that all is well ?
    Shōgun
  • 30,622 posts
Posted 01 December 2010 - 07:50 PM
How's the door alignment? Check especially the lower corner opposite the hinge. If the door sticks out a little bit from the cabinet at that corner while closed, there's a misalignment problem that could affect the door switches in the latch assembly getting actuated.
