PHugger
Whirlpool Duet F06 Error
7 posts in this topic
I have a Whirlpool Duet front loading washer that has just started throwing an F06 error code. I read a post about this error here -
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
but my machine doesn't seem to be acting in any of the described ways.
The tub spins very easily by hand before I power it up. I put the machine into the spin cycle. It starts spinning slowly and then speeds up to a decent speed (not sure if it's at the max or not) for maybe 3 minutes or so. It stops spinning and the 'time remaining' display starts to blink for a minute or two. The time display will stop blinking and it seems to try to spin up again (repeats the blinking another time or two), but does nothing and eventually displays the error code and beeps.
Can anyone help me get to the cause of the problem? I'd hate to start replacing parts unless I have some assurance that this is what's needed.
Best regards,
PCH
F06 DRIVE MOTOR TACHOMETER ERROR
The control is unable to properly detect motor speed and the machine will shut down.
If a failure occurs during high-speed spin, the door will be unlocked after three minutes.
Potential Causes
Verify the shipping system including shipping bolts, spacers and cables are removed.
Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU),
and between the MCU and the Central Control Unit (CCU).
Check the Drive Motor.
Check the MCU.
Thanks I had already seen that information in the thread I linked.
The motor does run and spins the drum at high speed, but then it stops and throws the F06 error.
This would lead me to believe the motor in working and that the MCU works for at least some period of the Spin Cycle.
Hard to know where to start.
Best regards,
PCH
Run the model number by me again, budrow, I think I missed it the first time.
It's a Whirlpool Duet HT
Model #: GHW9460Pl1
Thanks,
PCH
If you did everything in the first link you posted, including undoing and reconnecting all harness connectors and you still get F06, then you need to replace the MCU. Whirlpool has updated the software in the new boards.
Part link for MCU==> http://www.repairclinic.com/PartDetail/Motor-Control-Unit/1184161?modelNumber=GHW9460PL1
Thanks for your help. I'll check the harness over carefully and if it continues to fail, order the MCU from you of course!
Thanks,
PCH
