storchs
ge side by side fridge not cooling well
5 posts in this topic
Have a GE side by side fridge/freezer about 8 yrs old (TFX22CRBB).
Freezer gets and stays plenty cold.  Fridge however isn't quite cold enough.  If I lower thermostat temp for fridge, compressor runs (at least the something is running and humming along) but runs constantly without getting the fridge cold.
I've checked the evaporator for ice...just a tiny bit of frost on the lower section but the coils were 99% free of ice.
Any suggestions?  Evaporator fan?
storchs (steven)
***I've checked the evaporator for ice...just a tiny bit of frost on the lower section but the coils were 99% free of ice.***
The whole evaperator coil should have frost covering it, are you meaning only 1% has frost and the other 99% does not???  If this is so you have  major sealed system problems. If you had the evaperator cover off you would have seen if the fan motor was running or not.  If the fan is not running the coils should still be all frosted,,,,assuming you have the frig on and running when you removed the back panel.
Yep, just a bit of ice down at the bottom...most was bare, uniced metal.
Awe sh......uger!  There goes a thousand bucks for a new one.
Yep, fan was running.  Condenser fan runs fine too.
Any brand suggestions or are we just shooting in the dark on these things?  (New 22 cu ft side by side).
Whirlpool, Roper, Estate, Kitchen Aid, the simpler the better, no electronic gizmos..Kitchen Aid is the top of the Whirlpool line....
